Dual-band vs. multi-band GNSS: what’s the actual difference?
Centimeter-level GNSS positioning was once the preserve of professional surveying equipment. Today, RTK and PPP are moving into tractors, lawn mowers, delivery robots, drones, and passenger vehicles. Design engineers are faced with a growing list of antenna options, with datasheets offering L1/L2, L1/L5, L1/L2/L5, and full-band configurations.
It is tempting to assume that more bands mean better positioning. In practice, the right frequency configuration depends on what the GNSS receiver can track, the positioning requirements, and the application.
Why high-precision systems use more than one frequency
The ionosphere delays GNSS signals by an amount that varies with frequency. According to the European Space Agency’s Navipedia, ionospheric delay for single-frequency receivers can reach tens of meters. Comparing two frequencies lets the receiver estimate and remove that error. ESA notes it can be removed “up to more than 99.9% using two frequency measurements” for the first-order effect.
What each band brings
  • L2 has a long heritage in survey and RTK work.
  • L5 is a modernized signal. According to GPS.gov, it was “designed to meet demanding requirements for safety-of-life transportation and other high-performance applications,” with “greater bandwidth for improved jam resistance.”
  • L6/E6 carries satellite-delivered PPP and PPP-RTK correction services such as QZSS CLAS and Galileo’s High Accuracy Service, which is free of charge and targets under 20cm horizontal accuracy.
  • L-band is used for satellite-delivered correction services from commercial providers.
Relevant resources
Dual-band vs. multi-band GNSS. The real difference is frequency coverage
A dual-band antenna typically covers L1 plus either L2 or L5. A multi-band or full-band antenna extends coverage to L1, L2, L5, L6/E6 and L-band. The core difference is which signals the antenna can pass to the receiver.
That is why the antenna should be chosen to match the frequencies the receiver tracks. If the receiver cannot use a band, an antenna covering it adds nothing. If the antenna leaves out a band the receiver depends on, the system loses capability. An L1/L2 RTK engine needs L2 coverage, and a receiver using satellite-delivered PPP corrections needs L6/E6 or L-band. An L1/L5 antenna, meanwhile, suits many cost- and size-sensitive designs built around modern dual-band receivers.
What a multi-band system adds
Faster convergence and a stronger fix: Extra frequencies give the RTK engine more observations, helping it resolve carrier-phase ambiguities faster, as peer-reviewed research confirms.
In Quectel’s experience, moving from L1/L2 to L1/L2/L5 cuts convergence time by about 20%, while L1/L2/L5/E6 can cut it by 40–50% in the same environment. The gap widens in harsh environments, where a multi-band system can converge in seconds rather than tens of seconds and is less likely to lose its RTK fix. Actual gains depend on the receiver, correction method and signal environment.
Stronger resistance to spoofing and jamming: Spoofing an L1-only receiver is now relatively easy. It is harder with L1/L2, and can be considerably more challenging with a multi-band system, because the receiver can compare observations across bands and spot inconsistencies.
Multi-band is not immune to sophisticated spoofing, but it raises the bar. It can also help against jamming, as the receiver can keep using unaffected bands, including L5 with its wider bandwidth.
What this all means
Choosing between dual-band vs. multi-band GNSS is not about which is more accurate. It is about matching frequency coverage to the receiver, the positioning requirements and the application. To explore the options, talk to Quectel’s GNSS team or browse the GNSS antenna range.
Look out for part two of our series on dual-band vs. multi-band GNSS antennas, ‘Why more bands don’t automatically mean better GNSS antenna performance’.
Relevant resources
